MDCII
So I have a 1971 301 (3cyl gas) with FEL that I purchased a few months ago. Tractor runs pretty good but had a bogging issue and charging issue. I know the previous owner and know that it had been sitting for quite a while so I tuned it all up fixed the charging issue (voltage regulator) and had the carburetor rebuilt..... Again the tractor runs and idles very well except for the higher gears. From gears 1-5/6 it takes off pretty smooth and easy under power. However it 7/8 particularly it just wants to stall. Boggs way down and doesn't want go at all. I would say it gets progressively worse through the gears in general but I can get it moving in all of the others. Any suggestions from some of you experts would be great! After rebuilding the carb and setting the timing I'm not sure what else it could be?
Thanks a lot
Marcel
Thanks a lot
Marcel
