JD 300X Series Maint Question
   / JD 300X Series Maint Question #1
AKKubota
Alaska
JD 2520
I have a 324X. I can not find in the manual where it talks about servicing the transmission.
   / JD 300X Series Maint Question #2
If your talking about changing the trans. oil, I don't belive your supposed to. I pretty sure it's supposed to last the entire life of the tractor with out servicing. That being said there is a thread with a bullitin on how to change the oil if you want to. It is in the lowes/ home depot tractor thread I belive. I would keep it cleen and grease your "u" joints. A clean transmission is a happy transmission.:D
   / JD 300X Series Maint Question #3
I have been considering the X300 series myself, but was turned off when I downloaded the manuals from the JD website, and found that even going up to the X324 the transmissions are all sealed - "Fluid is good for the life of the unit". I wasn't going to fork over $4k for a tranny that didn't have at least a drain plug.
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
2013 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A54607)
2013 FREIGHTLINER...
2010 John Deere TX Gator 4x4 Utility Cart (A52377)
2010 John Deere TX...
2014 Ford Explorer AWD SUV (A53424)
2014 Ford Explorer...
Scaffolding (A52377)
