Loader JD 300CX & 400CX Buckets
   / JD 300CX & 400CX Buckets #1
pane056
Lake City, Michigan
CaseIH 685 & JD 3320
Hello;
Will a 300CX bucket mount on s 400CX loader and visa versa?
I am ordering a grapple and the company tells me they only set them up to fit the 400CX loaders and if I want it to fit a 300CX I will have to do the fitting and welding myself. If this was 2010 it would be no problem but in 2011 I had a stroke and this year total knee replacement. Therefore when the grapple is dropped off here I would like to put it to work without having to work on it.
Seems to me the only differance would be the center to center measurement on the bucket hooks.
thanks, nicholas
   / JD 300CX & 400CX Buckets #2
The 200, 300 and 400 Series Loaders all use the same JD Quick Attach brackets - you should have no problem at all
Hello Mr. BleedGreen;
Thank you very much. Things will be much easier for me now. nicholas
   / JD 300CX & 400CX Buckets #4
pane056,
Did you end up getting the grapple? If so, was it a direct hook-up or did you need to modify anything? Thanks.
   / JD 300CX & 400CX Buckets #5
EDIT: Correct
The 500 series loaders place the lower pin around 2" lower from the top bracket than the 200/30/400 series loaders. Some implements have both sets of pins, but many do not.
Here is an example where you can see both sets of pins on an implement:
   / JD 300CX & 400CX Buckets #6
Attached to a 300 series loader:
   / JD 300CX & 400CX Buckets #7
Sorry to say, but this is incorrect.
The 400 series loaders place the lower pin around 2" lower from the top bracket than the 200/300 series loaders. Some implements have both sets of pins, but many do not.
I think you have the loader size break wrong.
Upper pin 200, 300 and 400 loaders. Lower pin 500 loaders.
   / JD 300CX & 400CX Buckets #8
I think you're correct, oops.
REDBALL 4R HOODED SPRAYER (A52708)
REDBALL 4R HOODED...
Year: 2024 Make: Chevrolet Model: Tahoe Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: (A56859)
Year: 2024 Make...
2013 HINO 338 26FT BOX TRUCK (A58018)
2013 HINO 338 26FT...
Terms & Conditions of Auction (CHECKOUT DATES) (A59213)
Terms & Conditions...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
2020 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A58018)
2020 FREIGHTLINER...
