JD 3005 3 pt hitch "bounces" every few minutes
   / JD 3005 3 pt hitch "bounces" every few minutes #1
northernexposure
Ohio
John Deere 3005, 110TLB
My Deere 3005 3 pt hitch bounces every few minutes when I have it raised with the box blade on it. Its a Woods 5' box blade. The tractor only has 120 hours on it. Can it be that the box blade is too heavy, or is there an adjustment that needs to be done? It seems fine with lighter implements.
   / JD 3005 3 pt hitch "bounces" every few minutes #2
My 4410 did the same thing. On the left side rockshaft arm there is a short linkage from the rockshaft arm going down to a shaft which goes into the three point hitch housing. On the linkage there is a short threaded rod that has two nuts on it that are on each side of a swivel. Loosen one nut and either lengthen or shorten that rod. If the three point hitch quits surging then you know you've adjusted the right way. If the surging gets worse then go the opposite way. That should cure your problem. Make sure you keep track of the amount of turn on the nuts so that you can go back to where they were if this doesn't work on your tractor. I would try half a turn at a time untill the surging goes away.
   / JD 3005 3 pt hitch "bounces" every few minutes #3
Incorrect adjustment of feedback rod could cause the rockshaft housing to break. Hunting (hiccuping) is normally caused from a leaking hyd component such as control or relief valve or leaking rockshaft piston seal. .
   / JD 3005 3 pt hitch "bounces" every few minutes #4
If you have a service manual, you'll find the plug for the pressure relief valve under the operator's seat. That would be the first place I'd look since it's easy to get to. There's also a check valve in the system that might be cycling when it shouldn't be.
BTW, if you added shims to up the hydraulic pressure (a lot of 790/3005 owners have done so), remove those shims and see if that fixes the problem.
Added: I re-read the original post...the tractor has 120 hours on it, so it's probably still in warranty....if so, let the dealer handle any repairs.
2008 Bobcat S250 Skidloader (RUNS) (A50774)
2008 Bobcat S250...
1997 International F-4900 T/A Dump Truck (A50323)
1997 International...
2006 Pearson Quantum Hale Pumper Fire Truck (A50323)
2006 Pearson...
1998 WELD-IT COMPANY FUEL TRANSPORT PUP TRAILER (A52472)
1998 WELD-IT...
Set of AG R4 Wheels and Tires (A52748)
Set of AG R4...
Bobcat 709 Skidloader Backhoe Attachment (A50774)
Bobcat 709...
