JD 3000 series front 3pt hitch
   / JD 3000 series front 3pt hitch #1
Fargo Snow and Ice Management
Does anyone know if the front 3pt hitch will work with standard 3pt attachments? Looking at the dealer pictures it looks like if I take the quick hitch off (the triangle piece) that the arms would work with a normal 3pt implement.
I ask because I'd like to put my own snowblower on the front that is narrow (52") to fit on sidewalks. I have the gearbox to reverse the rotation and reduce the RPM to make it work. I'm about to buy a 3720, and would like to use my Normand snowblower instead of the 60" JD one, so I'm hoping the hitch will work. (then I'll just need to have a custom PTO shaft made)
Thanks!
   / JD 3000 series front 3pt hitch #2
Does anyone know if the front 3pt hitch will work with standard 3pt attachments?Looking at the dealer pictures it looks like if I take the quick hitch off (the triangle piece) that the arms would work with a normal 3pt implement.
Thanks!
Short answer is no. The two lift arms are too narrow. That said, I guess with enough modifications anything is possible.
If I had to guess Deere did this as a safety measure. In other words a way for them to control the weight that's put on the front hitch. The hitch only has one hydraulic cylinder to do the lifting.
As far as I know Deere only offer three attachments (their attachments) for this front hitch, blower, blade, broom.
   / JD 3000 series front 3pt hitch #3
I bought one. Haven't installed it on the tractor yet. My guess is JD went this route to be "global" . I've seen European JD's with front 3 point hitches for years. Guessing cost cutting measures. It seems like to me the lift capacity is there. Category "o" attachments look like they would fit. I'm going to make mounts for my rear blade to fit up too the hitch. That's my winter project.
2013 KENWORTH T800 TRI AXLE CRANE TRUCK (A52472)
2013 KENWORTH T800...
2011 INTERNATIONAL MA035 ROUSTABOUT TRUCK (A52472)
2011 INTERNATIONAL...
2023 EAST TEXAS 40FT GOOSENECK TRAILER (A52576)
2023 EAST TEXAS...
2022 Adams CLC-1013 Conveyor - New (A52748)
2022 Adams...
2003 GMC C7500 16ft Cab and Chassis Truck (A51692)
2003 GMC C7500...
2016 LINK-BELT  235X3 SPIN ACE EXCAVATOR (A52472)
2016 LINK-BELT...
