Backhoe JD 300-D backhoe not movin...
   / JD 300-D backhoe not movin... #1
boomer7b
have a early 90s jd 300d, starts and runs but will not move, the shaft moves forward and reverse, into the rearend but will not move any help would be greatly appreciated. brian
   / JD 300-D backhoe not movin... #2
Welcome to TBN:D
Can't help with your problem...other than giving your post a little bump up to the top;)
   / JD 300-D backhoe not movin... #3
It sounds like you will need to tear in to the rear end :(
   / JD 300-D backhoe not movin... #4
Which shaft is moving? Do you have the transmission opened up to see shafts? You could have differential problem or one of the stub shafts connecting differential to the axle housing could be sheared off.
2013 Nissan Pathfinder Multipurpose Vehicle (MPV) (A51694)
2013 Nissan...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
2022 JOHN DEERE 410E II (A52472)
2022 JOHN DEERE...
1995 Rinker Captiva 190 (A52748)
1995 Rinker...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
DAEWOO MG 250-3 (A52472)
DAEWOO MG 250-3...
