Backhoe JD 300-D backhoe not movin...
   / JD 300-D backhoe not movin... #1
boomer7b
have a early 90s jd 300d, starts and runs but will not move, the shaft moves forward and reverse, into the rearend but will not move any help would be greatly appreciated. brian
   / JD 300-D backhoe not movin... #2
Welcome to TBN:D
Can't help with your problem...other than giving your post a little bump up to the top;)
   / JD 300-D backhoe not movin... #3
It sounds like you will need to tear in to the rear end :(
   / JD 300-D backhoe not movin... #4
Which shaft is moving? Do you have the transmission opened up to see shafts? You could have differential problem or one of the stub shafts connecting differential to the axle housing could be sheared off.
New 40ft High Cube 6 Door Container (A53002)
New 40ft High Cube...
2020 KUBOTA RTV...
2012 Ford Escape XLS SUV (A51694)
2012 Ford Escape...
2010 Chevrolet Malibu Passenger Car (A51694)
2010 Chevrolet...
17604 (A51694)
17604 (A51694)
2013 Audi Q7 AWD SUV (A51694)
2013 Audi Q7 AWD...
