JD 300 anti freeze in oil, diesel 3179
   / JD 300 anti freeze in oil, diesel 3179 #1
lowufo
warren maine
JD 300 industrial 1965-73 era
Hi All
removed oil pan to remove broken dip stick. found anti freeze in oil. engine was supposed to be overhauled by PO. I have put at least 150 hours on it always ran well.Suggestions ?? should I try to just re torque the head ?? or go for a new head gasket (hoping that's the problem ) I have never done one of these before. No manual, any pointers tips . btw no white smoke. any other place water could get in ?
Thanks !
   / JD 300 anti freeze in oil, diesel 3179 #2
This engine uses cylinder liners. Were the liners replaced? It's possible the liner to block seals are leaking, or cracked head, blown head gasket.
It might be possible to pressurize the cooling system and see the leak with the oil pan off. But I have no experience doing this.
   / JD 300 anti freeze in oil, diesel 3179 #3
Ditto what Zebrafive stated.
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50775)
IF YOU BID ON AN...
2008 Honda Pilot SUV (A53117)
2008 Honda Pilot...
2019 Infiniti QX60 SUV (A51694)
2019 Infiniti QX60...
2009 MAC MFG 53' WALKING FLOOR REFUSE TRAILER (A53426)
2009 MAC MFG 53'...
2006 Mercedes-Benz E350 Sedan (A51694)
2006 Mercedes-Benz...
2003 Atlas Copco 75kW ABB Rotterdam 220psi Air Compressor (A52377)
2003 Atlas Copco...
