JD 2xxx Series question
   / JD 2xxx Series question #1
drg1
Missouri
1532 hydro
Looking at the various models, narrowing it down to the 2720...My question has to do with the loader hyd lines..I see that they are routed fairly low to the ground from the main frame...Has anyone had issues with the hoses being ripped away or snagging them on ground brush or other foreign obstacles?? Thanks for the replies
   / JD 2xxx Series question #2
I have a 2320 and it has very similar routing for the hydraulic lines. I have never had a problem and have used the tractor clear several acres of sagebrush. I do try to be careful but there have been many times where the sagebrush was tucked up underneath the tractor and was not a problem when it rubbed across the hoses.
   / JD 2xxx Series question #3
I have a 2520 and pretty much the same response as Ed posted.
Good luck with your model decision.:thumbsup:
Greg
   / JD 2xxx Series question #4
Same here as in what EdC and glc24 said. Don't let that stop you. I had the same concern, originally.
   / JD 2xxx Series question #5
I have a 2520, and have not had any problem with the FEL lines. I also have the diverter valve, so mine hang even lower because there is another row of connections below the original ones.
However, I did actually have a problem with one of the lines at the diverter valve. When it was installed by the dealer, per the instructions from Deere, one of the lines is routed in such a way as to allow the 3PH lift arm to make contact with it and break it off at the fitting. After I took a shower in hydraulic fluid, the line was replaced and rerouted in a way that prevented any contact.
   / JD 2xxx Series question #7
2520 here and never a problem with the hyd. lines catching on anything. Make sure the standoff is in place that mounts to the right side of the operator platform. That holds them up pretty much out of the way.
   / JD 2xxx Series question #8
I cant say for sure, but I think about ALL tractors have hydraulic lines somewhere underneath that could potentially be snagged.
I know my kubota has them rught under the right floorboard. I made a thick shid plat to protact them because I dod catch one. Didn't break it but it did bent the metal 90* fitting a bit.
So dont let the little things like that stop you. IF you are worried about it, make a skid plate for it.
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54607)
2015 FREIGHTLINER...
2009 Bruton T/A Enclosed Livestock Trailer (A52377)
2009 Bruton T/A...
2019 HINO 195 LCF BOX TRUCK (A54607)
2019 HINO 195 LCF...
2021 Doyle 8 Ton Trailer Tender (A53472)
2021 Doyle 8 Ton...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
