JD 2940 Rearend Noise
   / JD 2940 Rearend Noise #1
gannman
I have a JD 2940 that just started making a noise in the rearend. everytime i let off the throttle the and the tractor is slowing down under compression from the engine a terrible knocking sound comes from i think the rearend. has anybody ever had this happen to them? any ideas?
thanks
   / JD 2940 Rearend Noise #2
My FIL was trying to get the little bucket scoop to dump by popping the clutch--repeatedly--and his started making a noise like that. He has an H Farmall. I pulled the top cover, and he had broken the bearing retainer on the left axle. Wasn't too bad of a repair job, but he learned a lesson. Hopefully yours is something simple, like maybe a loose wheel. Good luck.
   / JD 2940 Rearend Noise #3
I think I'd jack that sucker up and rotate the axles by hand and see what I felt/heard.. maybee drain the diffy into a strainer and look for metalic particles as well, as a then-prelude to teardown, pending the results of those observations..
Soundguy
thanks for the ideas i will try that tonight.
2012 Ford F-350 Mechanics Service Truck (A51692)
2012 Ford F-350...
2017 Taylor-Dunn B0-248-36 Electric Utility Cart (A50324)
2017 Taylor-Dunn...
2012 INTERNATIONAL 4300 26 FT BOX TRUCK (A52577)
2012 INTERNATIONAL...
JOHN DEERE 4066R (A53084)
JOHN DEERE 4066R...
2019 CATERPILLAR 289D3 SKID STEER (A51246)
2019 CATERPILLAR...
UNUSED CFG INDUSTRIAL QK20R EXCAVATOR (A51247)
UNUSED CFG...
