JD 2755 trans oil light
   / JD 2755 trans oil light #1
Miller_tractor
I have a JD 2755 hi/lo trans, after it gets up to operating temp with the pto on and the hi/lo selector in hi the trans oil light comes on, only at an idle. If you bring the engine speed up it goes off, or if you kick the hi/lo into lo. However it does not always go off when you turn the pto off, sometimes it will, sometimes it won't. Also when this happens there is a knocking noise that grows with engine speed, it also goes away after a few seconds of elevated engine speed.
I believe when the light comes on it is a flow issue, I have tested pressure and it is sufficient (2000+psi) I dont have a flow gauge so I cant do that. I have changed the filter and cleaned the screen.
The front pump was rebuilt in 2004, and probably has 1000 hrs on it.
There is no hay this year so I want to get this fixed
   / JD 2755 trans oil light #2
I assume you changed the fluid.
Is your transmission a collar shift or synchro?
That knocking sound is disturbing, it could be a bearing, which would not be good! It could be a constriction somewhere in the transmission oil passages.
Fluid was done at the beginning of the season, prob 200 hrs on it.
I pulled the screen out of the belly today, there wasn't much in it but I cleaned it any way. I also pulled the screen out of the front pump and replaced it.
Its a synchro with hi/lo
If I ever get to put any hours on it this season (hay fields are dead) I will get a flow meter and test the rear pump, it doesnt come on for a few seconds after reurning to idle so I am thinking it is draining the front resevoir and then the light is kicking on.
2023 New Holland CR10.90 Combine - Engine Hours - Separator Hours (A53472)
2023 New Holland...
2024 TIMPTE HOPPER 43FT HOPPER TRAILER (A53426)
2024 TIMPTE HOPPER...
KUBOTA ZD326 ZERO TURN LAWN MOWER (A51247)
KUBOTA ZD326 ZERO...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
(APPROX 100) UNUSED FUTURE 10' GALVALUME STEEL (A51248)
(APPROX 100)...
PALLET OF 6' X 12' SITE FENCE (A51248)
PALLET OF 6' X 12'...
