Miller_tractor
- Joined
- Jun 18, 2006
- Messages
- 11
I have a JD 2755 hi/lo trans, after it gets up to operating temp with the pto on and the hi/lo selector in hi the trans oil light comes on, only at an idle. If you bring the engine speed up it goes off, or if you kick the hi/lo into lo. However it does not always go off when you turn the pto off, sometimes it will, sometimes it won't. Also when this happens there is a knocking noise that grows with engine speed, it also goes away after a few seconds of elevated engine speed.
I believe when the light comes on it is a flow issue, I have tested pressure and it is sufficient (2000+psi) I dont have a flow gauge so I cant do that. I have changed the filter and cleaned the screen.
The front pump was rebuilt in 2004, and probably has 1000 hrs on it.
There is no hay this year so I want to get this fixed
