JD 2720 now available
   / JD 2720 now available #1
shot_gun
NJ
You can now order a 2720 and they should be hitting dealers by the last week of may.
   / JD 2720 now available #2
That's good news, shot_gun! Couldn't find anything on the JD website -- build your own, etc., though.
What are the differences between this new model and the 2520 or the 3005 model's?
Thanks again, for the head's up.
AKfish
   / JD 2720 now available #3
See my reply to an earlier 2720 post...
Info should be coming any day now. List price is $17299 for R3's or R4's. Here are the specs hopefuly.
MANUFACTURER
MODEL John Deere
2720
Engine
Manufacturer Yanmar 3TNV88
Engine HP (kW) - gross 31 (23.1)
PTO HP (kW) - Gear transmission ---
PTO HP (kW) - Hydrostatic transmission 23.5 (17.5)
Rated engine speed, rpm 2500
Type Direct injection
Operating range 1000-2650
Aspiration Natural
Cylinders/Displacement, cu. in. (liters) 3 / 100 (1.642)
Cylinder Liners Cast-in-block
Bore and Stroke, mm (in.) 88x90 (3.46x3.54)
Compression Ratio 19.1:1
Lubrication Pressurized
Cooling System Water pump
Air Cleaner Dry-type, two stage
Engine Shutoff Key switch
Engine Torque @ rated speed, ft./lb. (N/m) 63 (85.4)
Fuel Tank Cap., US Gal. (L) (Open; Cab) 7.1 (27); NA
Electrical
Type 12 volt
Battery Size (CCA) 500
Alternator (12 volt, amp) 40
Starter Size, hp (kW) 1.4 (1.04)
Fuel System
Type Diesel
Injection Pump Type Gear
U.S. gal./hr (L/hr) @ 100% load* 1.4 (5.3)
*Fuel consumption rate should be used for comparison purposes only. ---
Transmission
Std. Transmission; Forward/Reverse Hydro - 2 Range
Opt. Transmission; Forward/Reverse ---
Left-Hand Reverser NA
On-The-Go Shifting (Yes/No/Partial) NA
Direction Reverser; Forward/Reverse Twin Touch pedals
Final Drive Spur gear
Brakes Wet disk
Steering Power steering
Clutch; Wet/Dry NA
Clutch Disk Diameter, in. (mm) wet clutch ---
Drawbar Tongue Weight Capacity, lb. (kg) 562 (255)
Axle Capacity (in operation) ---
Front, lb. (kg) 1940 (880)
Rear, lb. (kg) 2426 (1100)
Creeper NA
Hydraulics
Type Open Center
Pump Rated Output, gpm (L/min.) 10.5 (39.6)
Steering 5.5 (20.8)
Implement 5.0 (18.8)
Pump Type Gear
Maximum Operating Pressure (PSI) 2421
Draft Control Type Position Control
Remote Control Valves Available 2
3-Point Hitch
Type Category I
Lift Capacity (24-in. behind link arms), lb. (kg) 1314 (596)
Lift Capacity @ lift link ends, lb. (kg) 1433 (650)
Power Take-Off (PTO)
Standard Standard Rear @ 540 RPM and Mid @ 2100 RPM std.
Optional ---
Control Independent
Clutch Wet disk
Brake (for Mid and Rear PTO) Wet disk
Fluid Capacities
Fuel Tank, gal. (l) 7.1 (27)
Cooling system (includes coolant bottle), qt. (l) 4 (3.85)
Crankcase with filter, qt. (l) 4 (3.6)
Transmission and Hydraulic System, gal. (l) gear ---
Transmission and Hydraulic System, gal. (l) hydrostatic 3.9 (14.6)
Front Axle Gearcase (MFWD axle), gal. (l) 0.9 (3.4)
Final Drive
Type Spur Gear
Engage On-the-Go Rear Differential Lock Yes
Operator Station
Rollover Protective Structure OSHA, SAE, ASAE
Rigid - Foldable - Telescopic Foldable
Platform - Flat/Straddle Flat
Gear Shift Location - Console/Floor Left-Hand-Side
Cab
Compliance ---
Visibility ---
Air Conditioning, Temperature Differential ---
Doors ---
Platform - Flat/Straddle ---
dB(A) Rating ---
Seat Suspension System ---
2WD Dimensions
Wheelbase, in. (mm) ---
Front Tread Range, in. (mm) ---
Rear Tread Range, in. (mm) ---
Minimum Rear Tread Setting, in. (mm) ---
Front Axle Clearance, in. (mm) ---
Turning Radius w/Brakes, ft. (m) ---
Turning Radius w/o Brakes, ft. (m) ---
Unballasted Operating Weight, lb. (kg) ---
Approx. Ship Wgt, lb. (kg) Open; Cab ---
MFWD Dimensions
Wheelbase, in. (mm) 65.2 (1655)
Front Tread Range, in. (mm) 32.7 (830)
Front Axle Clearance, in. (mm) 13 (330)
Turning Radius w/Brakes, ft. (m) 7.5 (2.3)
Turning Radius w/o Brakes, ft. (m) 8.2 (2.5)
Limited Slip Differential ---
Approx. Ship Wgt, lb. (kg) Open; Cab 1973 (895)
Standard Tires
2WD ---
Front ---
Rear ---
MFWD ---
Front 23x8.5-12 R4
Rear 14-17.5 R4
Miscellaneous
Underhood Muffler Yes
Joystick SCV Control Yes
Inboard Planetary No
Axle Type Flanged
Brakes - Type and Control Wet Disk
Try the configurator now. I just did it on the dealer side and we use the same version that you guys do. It should work.
   / JD 2720 now available #7
Doesn't look like it is there yet for civilians... :D
   / JD 2720 now available #8
That's pretty disappointing if accurate; exact same hydraulics as 2520, so all they added was a few HP. I don't seem to recall a lot of owners complaining about a lack of power in the 2520.
MANUFACTURER
MODEL John Deere
2720
Hydraulics
Type Open Center
Steering 5.5 (20.8)
Pump Type Gear
   / JD 2720 now available #9
Perhaps the 2720 is the 'fix' for the 3-point hitch problem?
   / JD 2720 now available #10
Try this, a little adjusting to the link for the 2520 configurator;)
Right click on the 2520 "build your own" and copy the link. Paste it into the address bar, replace the 5 with a 7 in 2520 and hit enter.
2008 Kenworth T300 T/A Knuckleboom Crane Truck (A50323)
2008 Kenworth T300...
John Deere 603 3 pt Mower (A50514)
John Deere 603 3...
2020 Western Star Tri Axle Dump (A47384)
2020 Western Star...
2018 Ford Transit 250 (A50120)
2018 Ford Transit...
Show Livestock Tie Up Rack (A50515)
Show Livestock Tie...
