JD 2630 brakes
   / JD 2630 brakes #1
kab65
John Deere 2630
I have just purchased a John Deere 2630. The brakes are causing me issues. The left pedal needs to be pumped the pressurize it, the right pedal does not move. I checked the oil level and the tractor has been sitting for 5 years
   / JD 2630 brakes #2
Welcome to TBN
I suggest to lubricate brake pedal pivot pin & piston. After RH pedal/piston is freed I suggest to bleed both brake circuits. Engine needs to be at idle speed while brake bleeding is performed.
   / JD 2630 brakes #3
I agree, start by freeing the pedals.
After sitting unused for five years, I would change all fluids, filters, and clean the sump screen.
2005 Hino 268 Truck, VIN # JHBNE8JTX51S10984 (A57453)
2005 Hino 268...
LOT OF PALLET RACKING W/ WIRE MESH SHELVING (A52708)
LOT OF PALLET...
Pallet of 10 Chains and 5 Binders (A57454)
Pallet of 10...
SPRING TOOTH HARROW (A52708)
SPRING TOOTH...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A55315)
GOODYEAR SET OF...
