JD 260 tire replacement
/ JD 260 tire replacement #1
dhvd79a
Tire tools $40 (already owned)
New rear tires $54 each
Breaking the bead on tires that have been on the wheels for 18 year.............................................................P R I C E L E S S /forums/images/graemlins/ooo.gif
/ JD 260 tire replacement #2
Put a little gasoline around the bead and let it sit for a little bit , this will soften things up and assist in bead breakage.
"Put a little gasoline around the bead and let it sit for a little bit "
Good thing I didn't think of that. THere were a couple moments where I would have taken the next logical step..... Light a match.
I did get them changed eventually. It was just interesting breaking the bead.
/ JD 260 tire replacement #4
Did you try driving over the tire sidewall with your car or truck? If done slowly, it should work. I've done it on automobile tires in the "old days" when I was too poor to have it changed.
Joe
/ JD 260 tire replacement #5
You can also use the edge on a loader bucket to break a bead loose.
2024 Better Built 7'x12' Trailer (A64127)
2024 Better Built...
Landhonor 72" Skid Steer Power Rake (A62679)
Landhonor 72" Skid...
2022 Magni TH5 5.19P (A63689)
2022 Magni TH5...
2017 Mack Semi (A64047)
2017 Mack Semi...
2002 Jeep Wrangler (A64127)
2002 Jeep Wrangler...
2008 New Holland T2420 (A62177)
2008 New Holland...
