JD 25A Roller bearing ends
   / JD 25A Roller bearing ends #1
Powderdreams
Anderson, AL
Kubota 7040
Anyone found a cap or cover that fits over the roller shaft end to keep this from occurring? Thank you.
Roller bearing ends minus accumulated debris.
   / JD 25A Roller bearing ends #4
Thanks for the picture
How about this shield solution John Deere is using.
Should be easy to fabricate.
Also try caulking the gap with a generous amount of silicone.
Dave M7040
   / JD 25A Roller bearing ends #5
Maybe fabricate a cap that attaches to the 3 bearing bolts. Might take a beating as it hanges out a little more. Don't think silicone will work as the shaft is always turning and probably just get tore off with the weeds.
   / JD 25A Roller bearing ends #6
Welding a strap thats a couple inches or what ever is need around the edge like Dave suggested looks like a pretty good idea. Would allow it to cool off and easy for maintence access.
Perhaps a pipe nipple cut as short as possible so as to only have a few threads left. Then welded on over and around the bearing. Then a pipe cap screwed on if your wanting complete coverage. This would allow you to access the bearing more easily if repairs become needed. May have to check somewhere besides a box store for a fitting large enough. Fabrication shop, commercial plumbing store or oil field supply house.
   / JD 25A Roller bearing ends #7
Check the Parts Catalogue. Your end plates and bearings have been superceded to the type shown in Daves pic.
The 3-bolt bearing housing is now a 2-bolt for the new/different roller shaft diameter and the Skid/Guard Plate protects the end of the shaft better.
You can weld on your own Skid. (Or have it done locally for loose change and/or Beer Vouchers).
2017 FORD F-550 XL SERVICE TRUCK (A51406)
2017 FORD F-550 XL...
TUBELINE TL50LSV LOT NUMBER 119 (A53084)
TUBELINE TL50LSV...
2019 HINO 195 16 FT BOX TRUCK WITH LIFT GATE (A52576)
2019 HINO 195 16...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
(INOP) VOLVO L70H WHEEL LOADER (A51243)
(INOP) VOLVO L70H...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
