JD 2520 Hi-Crop
/ JD 2520 Hi-Crop #1
tmajor
Platinum Member
NE PA
2010 MF 1529, Woods ZTR MZ1952, National Mower sickle bar circa 1963
Hey y'all,
Does anybody know, if a JD 2520 "Hi-Crop" uses a special Top-Link or the same, as any other 2520?
/ JD 2520 Hi-Crop #2
Yes it is different according to JDparts. should be the same as a 4010, 3020, 4020 and 2010.
/ JD 2520 Hi-Crop
Thanks! I called around and that's pretty much what I came up with, as well. They seem to be fairly pricey, if found!
/ JD 2520 Hi-Crop #4
2520 HC 3 pt center link is similar to 4010,3020,4020 & 2010 high crop but not identical to row crop tractors as end that mounts to tractor is from a utility tractor not row crop tractor. If I researched correctly the center link end(AT11685) in photo is only common to high crop tractors except the model 2010 which end fits both RC & HC styles
/ JD 2520 Hi-Crop
Thanks! A friend has a HC 2520, which are nearly non-existent (only 8 gassers made) and I'm doing some leg work to come up with the correct top link. In any case, they aren't cheap, if available!
/ JD 2520 Hi-Crop #6
Your best bet would be to find a center link for a ""junk 2010 row crop"" and not mention the words high crop. With their poor reputation junk 2010 should be around.
/ JD 2520 Hi-Crop
Thanks, I'll give that some effort.
