JD 2520 Governor
   / JD 2520 Governor #1
Wannabe Tractor Man
Conn.
John Deere 2520
Hi everyone! I have a question on the JD 2520. If I were to purchase a 3 pt hitch generator does the 2520 have a governor that will maintain generator rpm's without having to constantly adjust the throttle lever due to changing loads on the generator? If it's a set it and leave it, I'm OK with that but if you have to watch it all the time I don't think that's a good thing.
   / JD 2520 Governor #2
I have a 10KW IMD with AVR and yes it does maintain RPM from 0 to 80% load and probably higher, but I have never seem it go above 80%. I do observe a slight deviation on the Hz it will sometimes move 1 bar (2 Hz). I think that kind of tolerance is very good and probably as good or better than most generators of this size. I have mine driving two 200 Amp panels via two outdoor transfer switches, now I just need a power failure to give it a good test.
   / JD 2520 Governor #3
WannaBeTractorMan,
I have a JD 2305, 18 pto and I frequently wonder why almost every flail mower is speced out of my PTO range. the 2305 is rated to run tillers and bushhogs and I just can't get teh feeling out of my head that a flail mower is a slightly reconfigured tiller. And on that thought, it will run a tiller through our horribly tight, hard as brick clay that we get in Southern Illinois. While I do not have one, my neighbors operate something similar and have no PTO problems at all. My Grandfather ran a self powered flail mower that operated by a 12 HP GAS engine! I also can't but help feeling that I am being gimmicked into purchasing more tractor than I need. It is easy for me to recommend a flail mower for yourself, its just a little more tricky to take the plunge myself.
SI 2305
   / JD 2520 Governor #4
Depends on how sensitive your equipment is. My K B3200 will run my gen as long as the load is relatively constant. Anything that is real sensitive to hertz fluctuations can be a bit annoying but on the most part no problem. Just remember that you are limited with the hp as to how much you can generate.
22ft Progressive Finish Mower (A52128)
22ft Progressive...
2011 Ford Explorer Limited AWD SUV (A50324)
2011 Ford Explorer...
John Deere 1100 3 pt Field Cultivator (A50514)
John Deere 1100 3...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2019 FREIGHTLINER...
Skid Steer Plate Attachment (A50322)
Skid Steer Plate...
2022 TAKEUCHI TB2150 EXCAVATOR (A51242)
2022 TAKEUCHI...
