JD 2520 Exercise - Best use of Logs?
   / JD 2520 Exercise - Best use of Logs? #1
skidoo
Montana - Growing Zone 5
JD 2520, JD X749, JD110TLB
A couple weeks ago, we had a nice day to get outside and do some clean up. The 2520 got some FEL exercise :) . So, I am wondering opinions as the to best use (other than firewood) of logs this size?
   / JD 2520 Exercise - Best use of Logs? #2
If you have enough--maybe a local mill would saw them for you and you could build something with the lumber?
   / JD 2520 Exercise - Best use of Logs? #4
Well it looks like pine to me. Most pine has a lot of tar in it. And these logs have lots of knots. So the lumber would be of little value.
As far as firewood goes, I wouldn't burn pine in my wood stove. Too much creosote (sp?) which means more chimney cleanings and more chance of a chimney fire. But then again, I have lots of hardwoods.
   / JD 2520 Exercise - Best use of Logs? #5
Put a note in Craigslist asking for someone with a portable sawmill to saw up the lumber for a share (maybe split the lumber into two piles and take one.)
Then sell the boards you don't want. Take a look at what they are getting for knotty pine boards at Home Depot stores now- $6 for a warped 1X6
   / JD 2520 Exercise - Best use of Logs? #6
try your hand at wood carving w/ chain caw
may get good enough to make $$
Mitsubishi FG35 Forklift - 8,000lb Lift Capacity, LP Gas (A52748)
Mitsubishi FG35...
2020 INTERNATIONAL LT625 (A52472)
2020 INTERNATIONAL...
2018 HINO CONVENTIONAL TYPE TRUCK (A52472)
2018 HINO...
John Deere Gator Utility Cart (A50324)
John Deere Gator...
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A50323)
2016 Big Tex 14ft...
2016 JOHN DEERE 135G (A52472)
2016 JOHN DEERE...
