jd 24T baler
   / jd 24T baler #11
Look in the baler manual for the procedure to properly adjust those springs. Your clutch should actually get just a little warm after baling for a while if the springs are adjusted properly. Too tight can cause a whole bunch of problems, expensive problems. Also suggest getting proper JD springs when you have time to deal with it and have them shipped to you.
   / jd 24T baler
Thanks Barry, I will get the correct springs for the sprag. It seems to be working fine am just about finished so will have time to get the right stuff.
2013 MACK ELITE LEU613 GARBAGE TRUCK (A51243)
2013 MACK ELITE...
SET OF SKID STEER QUICK ATTACH PALLET FORKS (A51243)
SET OF SKID STEER...
2015 Clarke Power Gen 47KW (A50324)
2015 Clarke Power...
2015 DODGE RAM...
2011 PETERBILT 337 (A52472)
2011 PETERBILT 337...
