JD 2440 16.9x30 Pressure
   / JD 2440 16.9x30 Pressure #1
loganhorse
Bronze Member
Reynolds station ky
John deere 2440
Whats the recommendation for pressure on a 2440 with loader? Rear has fluid.
My rear one looks low since temp has changed.
   / JD 2440 16.9x30 Pressure #2
Look on the tire sidewall for the max rating. Actual pressure depends on load, tire size/type and number of plies. 4 ply ratings usually run at 35 psig max, 6 ply 45-50, 8 ply 60 and so on.
However, 4 ply 13.6 x 28 F1 (ag) rears on my Fords are rated 18 psig max. I have 3 different manufacturers involved in the 3 Ford's tires and all are the same size/plies and have the same max pressure rating. An F4 of that size in industrial probably would be 8-10 ply and rated 60 or better max....don't know, just speculating on the F4s.
Mitsubishi FG35 Forklift - 8,000lb Lift Capacity, LP Gas (A52748)
Mitsubishi FG35...
2012 Chevrolet Silverado 1500 LTZ Crew Cab Pickup Truck (A51692)
2012 Chevrolet...
NEW Fork Extensions (A53002)
NEW Fork...
2017 TRANSCRAFT TANDEM AXLE DROP DECK TRAILER (A52576)
2017 TRANSCRAFT...
2022 New Holland Powerstar 90 Tractor with Loader (A51573)
2022 New Holland...
