JD 2355 Starts, runs, slowly dies
   / JD 2355 Starts, runs, slowly dies #1
D Ash
JD 2355
So it's been pretty cold here, not quite polar vortex but cold (around 0 overnight, single digits daytime)
When I started up my 1988 JD 2355 this afternoon (after being plugged in for about 2 hours, it was about 9 degrees) it started right up but the rpms started dipping occasionally. Started driving it over to pick up some hay bales and the rpms kept slowly dropping, despite increased throttle until it finally died. Started it up again and it immediately revved up to match the throttle position (which was pretty high, trying to keep it from dieing) but then started to slide down again and died. After a couple more rounds of start and die, I brought over some diesel and added 5 gallons (it was at half a tank before, now closer to 3/4). I made sure it had more than the usual amount of cold weather additive in it (the rest of the fuel also has additive in it), started it up again and while the rpms kept dipping, it at least ran long enough that I could drive it back up the hill to be close enough to an outlet that I can plug it in! I let it run for a minute but the rpms were still wavering and dropping so I shut it off.
It's dark now (and the cab on this beast means it won't fit in the garage) so I am looking for first things to check in the daylight. My thought is that there is clearly some kind of fuel (or air?) restriction. Gelled fuel in the filter? (though I always put the additive in, so I wouldn't think so) Other crap in the filter? (I've only had the tractor since the fall, not sure when that was last changed) Water or air in the fuel? Hopefully not something more complicated like a fuel pump...
Any tips, recommendations or things to check appreciated. It's warming over the weekend and into next week, so I should actually be able to work on it without loosing fingers.
   / JD 2355 Starts, runs, slowly dies #2
my guess would be fuel gelling.. You can buy some 9-1-1 that will help ungel it.. but then you need to change the fuel filter..
for tonite - You could possibly cover the tractor with a blanket/tarp and then run a space heater under the tractor (the blanket will help trap the air) and see if that will thaw out anything that is frozen..
brian
Well, that would be the least complicated problem, I hope that's it! It's supposed to get up to 40 Monday and Tuesday, I'd think that would be enough to thaw it out. I guess I need to up the amount of additive I'm putting in.
   / JD 2355 Starts, runs, slowly dies #4
It's possible the check valve in inj pump that fuel return line attaches to is blocking flow of excess fuel returning to tank.
   / JD 2355 Starts, runs, slowly dies #5
Looks like its a CAV pump Jim.. no check ball fitting on the return like a Stanadyne..
   / JD 2355 Starts, runs, slowly dies #6
According to my parts catalog research it appears an '88 2355 would have a Roto-diesel inj pump with a check valve(key 2). Will a clogged check valve on Roto-diesel pump affect engine operation the same as with a Roosa-master/Stanadyne pump?
Thanks,Jim
   / JD 2355 Starts, runs, slowly dies #7
I just noticed JD parts shows a return line check valve on a 2555 Cav IP
   / JD 2355 Starts, runs, slowly dies #8
I see that.. no it wont slow it down, it'll blow the front seals out..
If u really want to check to make sure, take the RETURN line off & unscrew the return FITTING.. & start & run the motor..
Its gonna be messy..
2008 Chevrolet Malibu Passenger Car (A51694)
2008 Chevrolet...
1973 CATERPILLAR 988 LOADER (A52576)
1973 CATERPILLAR...
JOHN DEERE XUV590M (A53084)
JOHN DEERE XUV590M...
2015 HINO BOX TRUCK (A52472)
2015 HINO BOX...
2014 Nissan Rogue Select SUV (A51694)
2014 Nissan Rogue...
Toro Workman Utility Cart (A51694)
Toro Workman...
