jd 2350 temp gauge
   / jd 2350 temp gauge #1
tmacod1
jd 2350
I have jd 2350. The temp gauge is acting up. I have replaced the thermostat, sending unit, checked wiring. It will still measure hot with minutes of starting the tractor under no load. You can tap gauge cluster and the needle will jump to normal and then back to hot in a few minutes. Even when hot you can touch the coolant hoses with bare hands. Any suggestions? I was wanting to put a new gauge but it is part of the entire console. Can i just use an aftermarket gauge and the current sending unit?
   / jd 2350 temp gauge #2
If you use an aftermarket gauge you will need to use a sender to mach. The resistance will most likely be differant
2010 Chevrolet Tahoe SUV (A50324)
2010 Chevrolet...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A54811)
2019 Caterpillar...
CATERPILLAR 615C MOTOR SCRAPER (A51406)
CATERPILLAR 615C...
2016 WESTERN STAR 5700XE TANDEM AXLE SLEEPER (A54313)
2016 WESTERN STAR...
2016 CATERPILLAR TL642D TELESCOPIC FORKLIFT (A52705)
2016 CATERPILLAR...
Kubota RTV500 (A47384)
