JD 235 WITH SNOW PLOW AND SUITCASE WEIGHTS
   / JD 235 WITH SNOW PLOW AND SUITCASE WEIGHTS #1
235
i recently purchased a 2005 jd 235 and a 44" snow plow for it right away. the first snow i tried to plow without chains or weights. didnt work to well. so i went to valley ag and bought 5 suitcase weights for the rear and tire chains. now it plows. did anyone ever hear about putting a piece of pvc pipe on the bottom of the blade when plowing a stone drive way. so the stones dont get plowed up. i am very pleased with my new 235. does anyone else plow with theres.
   / JD 235 WITH SNOW PLOW AND SUITCASE WEIGHTS #2
I saw one on eBay today that had ski-like runners on each end to keep it off the gravel.
   / JD 235 WITH SNOW PLOW AND SUITCASE WEIGHTS #3
235
Welcome! I usually wait until the first 5-6" of snow to fall. Then I go out and drive/pack the snow down in my stone driveway with my pickup or my wife's car. If no more snow falls on top of it, the driveway will harden/freeze over within a 8 hour period. This will keep your driveway stone down where it belongs.
I live in Northeast Ohio and we receive a lot of lake effect snow, so this is something I do to my driveway every winter. I have a Toro Wheel Horse 520XI garden tractor with a 48" front blade. I have Ag tires with chains and 50 lb. wheel weights on the rear. I use to just leave my Turf tires on with chains and wheel weights. But, I found that the Ag tires have a lot better traction then the Turf tires.
arthurb,
   / JD 235 WITH SNOW PLOW AND SUITCASE WEIGHTS #4
The PVC is a good idea.
I have a snowthrower on my 225. I have a paved yard, except for a crushed stone drive up to my storage shed. I usually have to wait and pack that before I dare run the snowthower over it, otherwise is turns into a "rock chuckah." /forums/images/graemlins/grin.gif
   / JD 235 WITH SNOW PLOW AND SUITCASE WEIGHTS #5
I have not plowed with your combination, but I have plowed with an x595 John Deere and 54" front blade. I can say that it was most impressive. With a 2wd tractor such as yours mounting ballast and chains will allow you to plow most things. I am very happy you enjoy your machine. To me, the common thought that bigger is better is not always correct. When I was a kid I used to plow most of the drives in our neighborhood for spending money. We would have about four snows per year of usually between four and six inches. The was a fellow down the road from us that plowed with a good sized farm tractor and a rear blade, and I at the time had an 8123 12 hp Gravely with a 48" blade. Even with manual angling, I could plow three drives to one for the other guy. It was the front blade and the added manuverability that made the difference. Good luck and enjoy that plow.
John M
   / JD 235 WITH SNOW PLOW AND SUITCASE WEIGHTS #6
Welcome 235,
If you would have got a Kubota you might not have needed all the extra stuff just to plow snow. LOL Good luck with the new toy. /forums/images/graemlins/grin.gif
   / JD 235 WITH SNOW PLOW AND SUITCASE WEIGHTS #7
I have a 245 with a 48" plow. I run chains on turfs and 150# of weight, plus me (180#), and it goes where it wants to. I'm very pleased. It nicely compliments a walk-behind snowblower.
2013 VOLVO VNM TANDEM AXLE DAY CAB (A52141)
2013 VOLVO VNM...
2022 Ram Bighorn 2500 4X4 (A52128)
2022 Ram Bighorn...
Case IH 1020 Platform (A50514)
Case IH 1020...
1994 Peterbilt 379 Semi (A50514)
1994 Peterbilt 379...
Yale GLC050LXNVAE087 5,000lbs Propane Cushion Tire Forklift (A51691)
Yale...
