JD 2320 w/ Northern Tool 3ph log spliter
   / JD 2320 w/ Northern Tool 3ph log spliter #1
Rick5050
East TN
JD 2320
New 2320 being delivered tomorrow and I'd like to get a 3ph log splitter in the next few weeks. Does anyone have experience with the Northern Tool 3ph Splitter powered by the tractor's hydraulics? Specs for the splitter say a maximum of 11 gpm flow and 2500 psi. The JD 2320 flow rate is about half of that divided between pwr steering and implement; implement is 3.4 gpm and steering is 2.2 gpm. Is this splitter too much for the 2320? Or ... will it work, but be painfully slow?
   / JD 2320 w/ Northern Tool 3ph log spliter #2
It will be slower, but ask Kenny for a good run-down on performance. I was wondering myself if there might be a way to augment the hydraulic flow rate, and was going to ask Kenny if a PTO pump could be plumbed into the system to increase the flow.
I just purchased a Speeco 3pt log-splitter from TSC, and choose it because it can be operated both vertically and horizontally.
   / JD 2320 w/ Northern Tool 3ph log spliter #3
Welcome to TBN:D
It will be slow, no doubt about it, probably to slow to be very useful. I personally wouldn't use a 3PH splitter on a machine with less than 5GPM minimum.
Not really, and with a PTO pump costing about $400, plus the extra plumbing/filter/tank, it's just more cost effective to get a stand-alone splitter.
Is it hooked up yet? You are just at 5GPM, and my tractor is rated at 5.1GPM, so I am curious what the cycle times are at different RPM's so I have a baseline...
   / JD 2320 w/ Northern Tool 3ph log spliter #4
Not yet, it's supposed to be delivered tomorrow. I think I'll be okay using it with the 2520's 10+gpm. I'll probably post some pics when it's hooked up and let you know how it goes!
   / JD 2320 w/ Northern Tool 3ph log spliter #5
You will only have 5GPM to operate the splitter, NOT 10+GPM, read the specs again...Sorry to burst your bubble;)
Hydraulics
TypeOpen Center
Pump Rated Output, gpm (L/min.)10.5 (39.6)
Steering 5.5 (20.8)
Implement 5.0 (18.8)
Pump Type Gear
Maximum Operating Pressure (PSI)2418
Draft Control Type Position Control
Remote Control Valves Available 2
   / JD 2320 w/ Northern Tool 3ph log spliter #6
Okay, now I'm nervous...hope this turns out okay, can't afford a mistake at the moment.
   / JD 2320 w/ Northern Tool 3ph log spliter #7
I'm using a Ramsplitter made specificaly for CUTs. It has a smaller diam cylinder and shorter stroke to help with lower GPMs of some CUTs. I use it to split 4 ~ 5 chords of hardwood per year. Its works fine 99% of what I put through it. A few nasty crotches have halted the splitter but wedge and maul will fix those in a hurry.
IMHO this is a good splitter for the average Home owner buring some firewood and trying to save a few bucks. If your using a log splitter to make a living, go with a stand-alone unit.
Here is a link to what I purchased.
Ramsplitter Log Splitter Model 3PT Attachment, the Toughest Log Splitter on the Market
Here is a link to how I modified mine for QH compatiblity.
http://www.tractorbynet.com/forums/customization/121482-modified-log-splitter-quick-hitch.html
Good luck and let us know what you get.
   / JD 2320 w/ Northern Tool 3ph log spliter #8
I like the Split Fire 230 I bought. Save times since the blades moves back and forth so you can split in both directions.
I originally had a Wallenstein and sold it when I sold my original CUT.
   / JD 2320 w/ Northern Tool 3ph log spliter #9
I calculated the volume of the ram cylinder, and the corresponding rate of fill, and came up with a cycle time of aprox 15 secs each way. Time will tell.
   / JD 2320 w/ Northern Tool 3ph log spliter #10
Here is your solution. 7 sec cycle time and the tractor never ever feels the load. I really think it burns less than a 5 hp Briggs. I run it at 1700RPM but no load is on the engine.
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
1999 Ford F-550 12FT. Flatbed Truck (A51692)
1999 Ford F-550...
2011 TIGERCAT 234 KNUCKLE BOOM LOADER (A51242)
2011 TIGERCAT 234...
BE Quick Attach Snow Blade (A50514)
BE Quick Attach...
Miles read : 112,969 (A50323)
Miles read ...
Year: 2009 Make: Volkswagen Model: Jetta Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 (A51694)
Year: 2009 Make...
