Jul 21, 2014 / JD 2320 Coolant Change #1 KennyG Super Member Joined Jan 13, 2011 Messages 5,103 Location SW Michigan Tractor John Deere 2320 My next maintenance task on my 2320 is to change the coolant. Looking at it I can't see a radiator drain plug or petcock. Looks like I just have to pull the lower radiator hose. Am I overlooking a drain?
Jul 21, 2014 / JD 2320 Coolant Change #2 B beenthere Super Star Member Joined Aug 16, 2001 Messages 18,693 Location Southern Wisconsin, USA Tractor JD_4x2_Gator, JD_4300, JD_425, JD_455 AWS, added JD_455, JD_110, JD_X485(sold) KennyG jdparts shows a drain valve on the radiator. part # LVU801884 Shows opposite corner diagonally across from the upper hose connect.
Jul 22, 2014 / JD 2320 Coolant Change Thread Starter #3 OP KennyG Super Member Joined Jan 13, 2011 Messages 5,103 Location SW Michigan Tractor John Deere 2320 Thanks. Looks like I need to crawl under it this weekend and look closer.
