JD 2305 w/ 47" JD Snowblower - PTO hitting Tie Rod Shaft
   / JD 2305 w/ 47" JD Snowblower - PTO hitting Tie Rod Shaft #1
kyrholland
John Deer 2305
Hi, My JD setup is making a racket... some due to loose sprocket/chain - replaced the sprocket and chain/tightened... Some of the noise might still be that I was not paying attention to aligning yokes.... got that from another thread.... but I've also found the PTO shaft is rubbing on the tie rod. I assume the CV kit I learned about on the treads might be a solution.
Have others had this interference and a solution, other than paying for a new CV conversion from the PTO shaft to the snow blower drive that I'd like to avoid if the yoke alignment takes are of most of the noise.
Thanks for thoughts.
Ky
Hi - the shaft of the pto is rubbing on the tie rod.
   / JD 2305 w/ 47" JD Snowblower - PTO hitting Tie Rod Shaft #4
Have you checked the tire pressures on your mule?
If the skids are fully retracted and the tire pressure is low that may cause binding issues.
2019 DODGE RAM 2500 HD SERVICE TRUCK (A51406)
2019 DODGE RAM...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
2008 Ford E-350 Cargo Van (A51692)
2008 Ford E-350...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A53473)
2012 JOHN DEERE...
2018 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2018 FREIGHTLINER...
2018 Chevrolet Silverado 3500HD 4x4 Crew Cab 9FT Flatbed Truck (A51691)
2018 Chevrolet...
