JD 2305 vs. 4ft rotary cutter?
   / JD 2305 vs. 4ft rotary cutter? #11
I mentioned in a previous post that the cutter you mentioned worked ok for me with the exception that I felt the closed rear end caused thick heavy vegetation to collect underneath and come out in balls. The person I sold mine to has a smaller tractor and indicates that it works good for him. The yellow model with one wheel does have an opening in the rear. One thing to keep in mind is that with your small tractor it might not pick up the yellow model high enough to clear the ground with the big wheel in the back. After switching to the 5' yellow model KK I have to adjust pull the pin and adjust the tractor lift arm from the middle hole to the top to lift higher. My tractor is CaseIH DX 33 so don't know what your lift hight or adjustments on the arms are. In other words the lift pins on the orange model are probably lower down and will lift higher by a small tractor.
Good info!
I will swing by TSC today and measure the lift arm height of the cutter and compare to my tractor. All of the SCUT's have cat 1 capability, but have limited lift height.:(
   / JD 2305 vs. 4ft rotary cutter? #13
I have the yellow 4' KK shredder. I don't attach the top pin to the shredder, just the two bottom ones. I leave the wheel in contact with the ground at all times and just raise and lower the front of the deck. Works fine for what I do.
   / JD 2305 vs. 4ft rotary cutter? #14
Hard to make is a realative question. I have a welder, a pile of old chain, and some angle iron and a drill press. making a chain guard would be more of an 'exercise' and of sweat equity / time.. vs 'hard. If you don't have the tools or supplies I mnetioned.. the sacle moves up a bit.
I have made guards from mudflaps and utility angle iron.. usually for under 20$ and takes about 1/2 hour.. is better than notheing.. though perhaps not as good at energy disipation for medium and large projectiles as a chainguard.. however it is better at small particle deflection as well as dust controll than a chain guard... I would reccomend at least the mudguard option if you mow within 100 feet of anything of value.. or anywhere near people / confined animals... If you have a small tractor then i double reccomend one or the other, as the geometry on a small tractor can make it so that some projectiles as well as dust can hit the back of the operator.. My 8n used to ding my back with an errant wood chip now and then due to the geometry of the cutter .. My larger tractors like my ford 5000 and Nh 7610s have a much higher op platform such that debri cannot travel in a sytraight line from under the cutter to my back.. however i still like guards on them, and have factory rubber guards on front of my batwing mower.. etc. since i mow around livestock..
Soundguy
cdhd2001 said:
P.S. Would a chain front guard be hard to make? I also have a left over semi truck mud flap to make a rubber guard.
Finally went to TSC to take a closer look at the 4ft yellow model they have in stock.
The yellow unit in person looks much heavier duty than the picture of the orange unit. I can barely lift the front of the unit (might have strained something). The weight (420 lbs) on the KK website might be a typo? The lift pins are 19.5" from the ground with the unit sitting flat on the pavement.
But, I remeasured the 2305 when I got home. Max height at the lift pins is 24". Is 4.5" enough lift height?
After looking over the yellow unit, I am leaning back towards the orange unit. The orange unit should be lighter and the lift pins are much lower. The orange units "seems" to be a better fit for the 2305.
But, from a durability and resale stand point, the yellow unit should be the better buy.
Now I am confused again!
   / JD 2305 vs. 4ft rotary cutter? #16
I have the LX4 for my 2305 and like it a lot. I've looked at some of the sub-cut implements from KK and they seem a little under-built to me. The standard yellow KK implements seem very substantial and well-built on the other hand. The 2305 does not lift the LX4 very high, but I have not found that to be a problem. It handles it just fine, although steering can get a little light on slopes with no front weight - I prefer to have the FEL attached (empty) and that adds enought front weight. I use the quick-attach hitch which extends the rear implements a few inches, and adds leverage too.
   / JD 2305 vs. 4ft rotary cutter? #17
Lift height seems to be the big snag. Decide if you want/need any more lift height and then make the decision. Yellow one is probably heavier too.. if you don't have front weight.. have a max lift height of 4.5" may be a 'safety' feature..;)
Soundguy
   / JD 2305 vs. 4ft rotary cutter? #18
Suspect you might measure to see if your lift arms will spread wide enough for the yellow model. You can install the pins pointing in instead of out but that might be a major consideration.
The JD 2305 has standard Cat 1 spacing, just limited lift height.
My box blade and post hole digger are Cat 1. My middle buster and 5 ft grader blade are the orange King Kutter Cat 0 spacing with Cat 1 pins.
On a side note, my wife and I examined the "woods" again yesterday. Definetly a lot of smaller stuff to use the rotary cutter to clear. But, most of our dense vegetation is larger than 1"-1.5" diameter. Guess I need to re-evaluate the economics of this decision.
Thanks!
First of all, let me say thanks to all who have given advice and helped with this decision!
Okay, after much deliberation, cussing & discussing, fussing and belly aching we finally made a decision.
Back story: Wife and I went to look at the yellow model today and decided that it would be too heavy. The yellow model requires me to build guards, so it is not "ready-to-run". TSC manager looked up the orange unit, these are out of season now and cannot be ordered until March. But, the manager did locate an orange unit in stock at a store 50 miles away (supposedly the last one left in the region). Drove over there, looked it over, and purchased it for $674 plus tax.
Biggest deciding factor was weight and pin height. I can lift the front of the orange unit (still heavy), but have a very hard time lifting the yellow model. Another plus is the closed rear and heavy rubber guard on the orange unit (I will be mowing about 50 ft. from the house).
I still need to add the gear oil and finish assembly.
Anyway, here are the pics!
2015 Nissan Sentra Sedan (A55758)
2015 Nissan Sentra...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
UNUSED (1) 5200# DROP AXLE W/ BRAKES (A54756)
UNUSED (1) 5200#...
1985 Eager Beaver 9D0W Tri-axle Flatbed Equipment Trailer (A50322)
1985 Eager Beaver...
2015 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A55788)
2015 Chevrolet...
