JD 2305 sub compact tranny overheating
   / JD 2305 sub compact tranny overheating #1
JCCinOhio
SW Ohio
JD 2305
My tranny is getting up to 225F during mowing with a belly mower. Outside is only 75Fish.
What are some things that would cause a hydrostatic transmission get that hot?
   / JD 2305 sub compact tranny overheating #2
Not sure about your particular tractor, but 225 may not be overheating. My previous two Kubota HST's would hover at 190-200 when worked hard. These were 10-11 gallon sumps.
You could clean out the transmission cooler, assuming it has one. I added a huge 3u hydraulic filter to the return line of a previous tractor, which both increased the hydraulic fluid volume and lowered the temps somewhat.
It's a sub-compact, no cooler and only holds a little less than 4 gallons.
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/slimjaro-vs-burnjaro-reviews-a-comprehensive-analysis-of-benefits-and-1044755
https://www.accessn...
2016 Freightliner 114SD Tandem Axle Dump Truck, VIN # 1FVHG3DV7GHGW6796 (A51572)
2016 Freightliner...
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A52472)
2013 XLR...
2015 VOLVO VNL TANDEM AXLE SLEEPER (A52577)
2015 VOLVO VNL...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
