JD 2305 Repetitive Diode Failure
   / JD 2305 Repetitive Diode Failure #1
Samw41240
Eastern KY
kubota m7040 JD 2305
Engine will not start. Replace fuel solenoid diode. Engine starts and runs fine for 1 to 30 minutes then dies and will not start. Have replaced diode 3 times with same results. Any help on what may be causing the diodes to keep failing?
   / JD 2305 Repetitive Diode Failure #2
Bad ground. Had the same issue with one of my Kubota's Cold not figure it out, finally my Kubota tech discovered the issue.
Is the frame ground from the negative battery terminal the only ground location?
John Deere Gator (A53317)
John Deere Gator...
6' SCRAPE BLADE (A52708)
6' SCRAPE BLADE...
20 X 20 CAR PORT (A58216)
20 X 20 CAR PORT...
2019 Chevrolet Tahoe SUV (A55973)
2019 Chevrolet...
LOT OF GALVINIZED Z BAR (A58374)
LOT OF GALVINIZED...
2011 Toyota Camry Sedan (A56859)
2011 Toyota Camry...
