JD 2305 Leaking Transmission Fluid
   / JD 2305 Leaking Transmission Fluid #1
bigrand
I have a JD 2305 with about 40 hours and I noticed a small transmission fluid leak. It's coming from the square head plug near the back of the filter on the rear axle. This is not the Hex head drain plug. Has anyone else had this problem? What is this plug for, is this just a plugged off port or another drain plug? Thanks
   / JD 2305 Leaking Transmission Fluid #2
I haven't experienced any such leak on mine after ~70 hrs, or so. If the bolt is on the axel, I doubt it's an extra port. Maybe a seal is leaking? How bad is it? If you can keep on top of it for now, you can schedule your dealer to come out and fix it. They should have a mobile service truck, and it should still be under warranty with only 40 hours. Good luck with it!
2010 EVCO SERVICE CO., INC. SWIVEL UNIT (A50854)
2010 EVCO SERVICE...
3000 Gallon Black Poly Water Tank (A49461)
3000 Gallon Black...
48ft Low Boy T/A Trailer (A49346)
48ft Low Boy T/A...
2007 Hyundai Santa Fe SUV (A49461)
2007 Hyundai Santa...
2010 Gleaner 9250 Draper Head  30' with Crary Air Wind System (A51039)
2010 Gleaner 9250...
2020 CATERPILLAR Tl1255D TELESCOPIC FORKLIFT (A51242)
2020 CATERPILLAR...
