JD 2305 leaking fluid like crazy
   / JD 2305 leaking fluid like crazy #1
Kevingrade4
Deere 2305
I've got a big leak on the rear right side. It's so wet I can't even see where its coming from. Does anybody know what's down there so I can look in the right place? Any ideas? Thanks in advance. Kev
   / JD 2305 leaking fluid like crazy #2
You will need to post more information, such as :
What is leaking
From the right rear of what
Running or not running
Other symptoms
Pictures
   / JD 2305 leaking fluid like crazy #3
Power wash and dry it to see where it's coming from. I assume it's hydraulic fluid since engine oil shouldn't be in that area. Most likely the 3 point lift cylinder or associated hoses/lines. Do you have an independent mower lift? Clean up the loader connections well to make sure it isn't coming from there.
   / JD 2305 leaking fluid like crazy #4
Cracked or hairline fractured housing?
Thanks for your help. I washed and dried it, put it up on jacks and took off the rear wheel. The fluid was leaking down one of the hydraulic lines attached to the pump. I replaced the two copper seals on the banjo bolt and it stopped the leak! That's the type of fix I like!
   / JD 2305 leaking fluid like crazy #6
Good news. Sometimes you get lucky.
Greenworks Commercial 82V CZ60R Zero-Turn Mower- BRAND NEW, NEVER USED (A55218)
Greenworks...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
2016 UTILITY VS2RAP 53FT REEFER TRAILER (A54607)
2016 UTILITY...
Black Galvanized Steel Fencing Kit (A53424)
Black Galvanized...
