JD 2305 engine stops when shifting from neutral to high or low range
   / JD 2305 engine stops when shifting from neutral to high or low range #1
perchb
Black Creek WI
John Deere 2305
John Deere 2305 engine starts and runs fine but when I shift to high or low range , the engine stops.shift to neutral
it starts right up again. Anyone know where the neutral switch is?
Perchb
   / JD 2305 engine stops when shifting from neutral to high or low range #2
I guess you have (like my newer tractors) an interlock switch that prevents you from starting when in gear to "protect you from yourself" (big brother). Either it is out of adjustment or defective. First place I would look for it is under the console....between the steering wheel and the floor, in that shrouded area where the shafts are located between your knees.
I said under the console because that is where the rods are that perform the function on mine. If yours is in another location then look under it's location.
2018 Freightliner Bucket Truck (A55973)
2018 Freightliner...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A55973)
2015 SkyJack SJ86T...
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A58214)
2014 MAGNUM...
2025 Star EV Capella Low Speed Electric Cart (A55853)
2025 Star EV...
2015 Ford Fusion Sedan (A55853)
2015 Ford Fusion...
2019 Ford Explorer (A55788)
2019 Ford Explorer...
