JD 2305 BH Sub Frame
   / JD 2305 BH Sub Frame #1
ekylaw
Kentucky, Eastern
Any other places to look for this option than Deere, can one be made at the local machiene shop and be just as effective?
   / JD 2305 BH Sub Frame #2
You can check with Woods, as they have the Groundbreaker hoe that will fit the 2305.
Why are you looking at just the subframe?
   / JD 2305 BH Sub Frame #3
if your machine still has warranty anything other than a deere part will void it. For example you make your subframe and then have driveline problems.
Just something to consider
   / JD 2305 BH Sub Frame #4
Where have you heard that? Can you quote a JD source?
The only backhoe-related warranty-voiding activity I have seen in writing
is the mounting of a backhoe on the 3-pt hitch.
LOOKING at just he sub frame because I have been told, and maybe my info is wrong, the 2305 needs the extra support to keep the backhoe from causing damage to the tractor its self. Maybe that is wrong.
I will be using the bh to help dig out trails and paths in the rocky hillside where I live.
Any advise will be very helpful
thanks
   / JD 2305 BH Sub Frame #6
So you already have a hoe? I am confused:confused:
The JD backhoe comes with a subframe, or are you trying to use a 3PH mounted hoe?
Details, Details, Details please:D
2025 CFG Industrial QK20R Mini Excavator (A59228)
2025 CFG...
DEUTZ MARATHON...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
KOMATSU WA270 (A58214)
4 Unused Montreal ST205/75R15 Trailer Tires (A55788)
4 Unused Montreal...
2018 Kubota RTV500 4x4 Diesel Utility Cart (A59228)
2018 Kubota RTV500...
