JD 2240
   / JD 2240 #1
Dartman_hd
Virginia
Wd45/Farmall 300
Hey everyone, old man just picked up about 1981 2240. I was looking for a rops with a canopy for him. I was just wondering if there was a place where I could draw a bead on a used one, or one off a junkyard salvage tractor. Thanks much!!!!
   / JD 2240 #2
Welcome to TBN
Abilene Machinery & Wengers would be where I'd start checking. Performing a part # search on JD parts reveals 15 tractor models that AR51143 roll-gard will fit on units with 28'' & smaller dia. rear tires & 22 models that AL70191 roll-gard for units with 30'' & larger dia rear tires
   / JD 2240 #3
Another thing to check is some states have programs that help pay for installation of ROPS on tractors.
At one time JD sold the ROPS at cost, I am not sure if JD still has that program.
I found one for my JD 2030 on Craigslist. The seller's tractor would fit under the loft in his barn so he removed it.
   / JD 2240
Thanks guys! Never thought there would of been a difference by tire size. Great info to know before you write the check. And I will definitely look into the program as it never hurts to save a couple clams when you can. Again, thanks.
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
2012 FORD F-150 XLT (A50854)
2012 FORD F-150...
F-800 POWER PUMP 800 HP TRIPLEX MUD PUMP POWERED BY 3412 CAT ENGINE (A50854)
F-800 POWER PUMP...
2013 INTERNATIONAL 4300 26FT BOX TRUCK (A51219)
2013 INTERNATIONAL...
2015 DODGE RAM...
2008 MAGNUM LIGHT PLANT (A50854)
2008 MAGNUM LIGHT...
