JD 2240 tachometer
   / JD 2240 tachometer #1
willy44
MI
John Deere 2240
Hello everyone, I have a 2240 and the tachometer doesn't work exactly. The rest of the dash works, fuel,temp, hour meter, lights. The only problem is that the tach says I am pulling 2000 rpm even when I'm idling, its got power but it goes to 2000 rpm and doesn't move off unless I really get on it and then it moves up 100-200 rpm. I bought the tractor like this assuming since it had power it would be something simple but after looking at it I found out the system is a more complicated that I thought. I didn't want to drive an hour to the nearest dealer so I was hoping someone on here had a schematic or some help as to what the problem might be and how to fix it. Thanks in advance.
   / JD 2240 tachometer #2
Is your tractor below or above SN 350,000? Early model tach is cable operated,later model is elect.
Its electric, the serial number is covered up by a brush guard but I think the tractor is an '81-'82.
   / JD 2240 tachometer #4
Check sender on LH frt of engine. I don't know ohm values.
Would that be the speed and hour meter sending unit, I looked it up on the JD site and it said that it is located on the timing gear cover. I haven't looked at it yet, just browsing the computer before I get home.
Sorry for the delay, I got sidetracked with a farmall h I'm currently trying to get running but the engine is stuck. Anyway I couldn't find any sensors on the left hand side of the engine (left side from the drivers seat) however it looks like behind the alternator there is some kind of wires going into timing gear cover, any thoughts.
   / JD 2240 tachometer #8
Sensor is part key 29
2013 Ford F-250 Ext. Cab Pickup Truck (A50323)
2013 Ford F-250...
Gravelly Pro-Turn 148 48in Zero Turn Mower (A48082)
Gravelly Pro-Turn...
2016 Ver-Mac S/A Towable Trailer Message Board (A49461)
2016 Ver-Mac S/A...
20 STEEL FLAT SHEETS (A50854)
20 STEEL FLAT...
2013 TRAVIS BODY & TRAILER, INC. ALUMINUM BELLY DUMP (A50854)
2013 TRAVIS BODY &...
2019 CATERPILLAR 326FL EXCAVATOR (A51242)
2019 CATERPILLAR...
