JD 2210 vs. Cub Cadet 7264
   / JD 2210 vs. Cub Cadet 7264 #11
You mention mowing 1 acre, and kepping snow off 300ft drive, so i would imagine that the 1 acre is ONLY the size of the area you want to mow, NOT the acerage of you land? The cub seems to be better for handeling the snow and dirt moving, but take into consideration the extra size and weight for mowing.
   / JD 2210 vs. Cub Cadet 7264 #12
You might want to look at the JD 4010. Two dealers that I checked price with on the 4010 were discounting it 20% because it is being replaced by the new 3000 series stuff. In driving the JD 2210 and JD 4010, they seem very much the same machine except the 2210 is missing cruise control and dual brakes on the 4010. The 4010 at 20% discount is $300 cheaper than the 2210.
I'm awaiting deliver of my 4010 with 410 loader and LX4 cutter; main delay is getting the toothbar in. The 2210 and 4010 essentially take the same attachments. Think the 2210 has a 210 loader though.
Ralph
Thanks, everyone for your advice. I have purchased the JD 2210 with FEL, 62C MMM, front snow blower, general purpose tires (rear loaded with Prestone), rear ballast box, Curtis soft sided cab and interior water heater. From what you have said, it looks like it will be ideal for my purposes. /forums/images/graemlins/laugh.gif
Le Roi 80-Gallon Air Compressor, 220 Volts (A59076)
Le Roi 80-Gallon...
Roll of 2-inch Vacuum Hose (A57453)
Roll of 2-inch...
2023 Bobcat E32i Mini Excavator (A57453)
2023 Bobcat E32i...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2013 BMW 328i Sedan (A55853)
2013 BMW 328i...
MARATHON 76KW GENERATOR (A58214)
MARATHON 76KW...
