JD 2210 HYDRO FLUID LEAK
   / JD 2210 HYDRO FLUID LEAK #1
JOEDFERG
Mantorville
DEERE 2210
GREETINGS -
FIRST POST --- I HAVE A JD 2210 WITH 400 HOURS ON IT. I USE IT TO MOW, SOME FEL & SOME GRADING. THE TRACTOR RECENTLY STARTED LEAKING HYDRO FLUID AFTER IT WARMS UP. IT LOOKS LIKE IT IS COMING OUT OF A TUBE THAT SITS NOT FAR FROM THE FILL SPOUT FOR THE HYDRO FLUID. IS THIS SOME TYPE OF OVERFLOW SITUATION, OR DO I HAVE OTHER ISSUES. APPRECIATE ANY INSIGHT!
Sorry about all caps... Did not notice.
   / JD 2210 HYDRO FLUID LEAK #3
There is a breather tube under the seat.. It not necessarily an overflow tube.
Have you recently changed the hydro fluid? Could it have been over filled?
I know 2 of us have had hydro leaking issues - but it was from bolts along the rear axle (probably caused by a gasket leak within the tractor rear end)
Brian
Brian
Wolverine Quick Attach Power Rake (A50514)
Wolverine Quick...
Bush Hog 176 3 pt Blade (A50514)
Bush Hog 176 3 pt...
2017 E-Z Beever M12R Towable Brush Chipper (A50322)
2017 E-Z Beever...
Yamaha Golf Cart (AS IS) (A50774)
Yamaha Golf Cart...
New Power Line 400 Plastic 3pt. Spin Spreader (A50774)
New Power Line 400...
2015 Big Tex 70PI 15ft Pipe Top T/A Utility Trailer (A50322)
2015 Big Tex 70PI...
