JD 216 Rear Transaxle
/ JD 216 Rear Transaxle #1
mwood
Chenango County, NY
JD 1023E
I broke the left axle housing of my JD 216. I have removed the wheel, hub and all the bolts which hold it in place. I have a replacement part...
But how in the world do you remove the darn axle housing? I can see the axle sticking out the end and there is a bearing there. The whole axle housing (actually, both pieces of the broken housing) move in and out (including the axle) about 1/2 inch. However, it will not come fully off.
Do I really have to break the transaxle in half and take all the gears and everything out to remove this housing?
Please help! I'm gonna need a haybine if I don't get this fixed soon /forums/images/graemlins/crazy.gif
/ JD 216 Rear Transaxle #2
I'm not sure which series transaxle is in the JD216. There is a spit washer (not a c clip) that has to come off of the axle before the axle housing will slide off. You also have to take the 4 bolts out of the transmission so the housing will slip off.
Sorry if I wasn't clear.
Thus far, the transaxle is removed from the tractor and is free of all else.
The wheel is removed, the snap ring is off and the wheel hub is removed. This leaves the splines of the axle exposed and I can see them come through the bearing in the end of the axle housing.
I then removed the four bolts holding the axle housing to the actual transmission / housing. I figured that then, the broken axle housing and the outer bearing (the visible one) would slide off the axle. It does not... /forums/images/graemlins/frown.gif
I also noticed something interesting... The axle housing is complete cracked all the way around. Therefore, there are two pieces of the axle housing to remove. (It broke next the flange the outer bearing is pressed into.) If nothing else, I figured that this broken piece and the included bearing would slide over the splines. But for some reason, it doesn't. /forums/images/graemlins/confused.gif
Is this simply a matter of more force? (If at first you don't succeed, get a bigger tool?)
Thanks for your help!
/ JD 216 Rear Transaxle #4
It should slide off, you may need to pry a little on it. If you give me your email address I can send you a repair manual that you can download. It may take a while especially if you have dialup. I worked on one earlier this spring. One thing I found is that if you leave one wheel on & you lay that wheel on the side it is easier to work on. You sure don't want all the gears falling out when you seperate the transaxle.
Check your PM. I sent you my e-mail address!
If I really get into this, i'll try to post some pictures of the whole event!
Here are some pictures of my restoration project that has stemmed out of trying to fix this broken axle housing!
This is the original tractor, minus the fender pan and gas tank. Not bad shape for never really being cared for in 20 years!
Here is a close up of the rear axle. You can see the fancy "drain pan" I used to drain the transaxle of it's fluid. Sadly, it looked like glitter had been poured in there, which is what is prompting me to take the whole thing apart and restore as best I can.
The crack in the axle housing is barely visible here.
Here is a close up of the crack.
I was doing a routine check of things when I noticed that there was oil on the inside of the tire. Since my wife drives this as much as me, i'm not sure how long it has been like this. With the tire on and the fender pan on, you really couldn't see this unless you were looking for it.
Also note, the parts guy at my local deere dealership said he'd only seen one broken axle housing in all his years and it was when a tractor rolled away from a guy and the back tire struck a tree. Still not sure how this happened! I'd like to think i'm careful /forums/images/graemlins/tongue.gif
/ JD 216 Rear Transaxle #9
I had a 212 that I ran like a D9 and broke three axle shafts so I became well versed in changing these. The shaft should pull right off once the wheel hub is removed but take the tranie right out and through it on a bench and tap the housing with a hammer. Of coarse it was a little more work changing the shafts than the housing because I had to split the transaxle housing and all the gears went rolling out and getting it back together was a real hoot but I got it done.
/ JD 216 Rear Transaxle #10
I may have an axle housing for you but am unsure what shape it is in. The tractor was in my barn when it burnt back in 99.
Thanks for the offer! Actually, there is a guy on e-bay selling one for 9.97 right now with something like $15 shipping. It appears to be in good shape. Since Deere wants $60 for it, I figure that unless people start bidding this up, I should be able to get it at a significant discount.
Actually, since when I drained the oil, it looked like glitter was pouring out, I split the diff. You are right! Lot's of gears in there. However, I guess I'm lucky. Another person on TBN here has the manual for the tranny! /forums/images/graemlins/laugh.gif This should help me get it back together. /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif
Well... for all you who care, (and most of you who I'm sure don't), I got the axle housing in the mail today. Decided it was time to get the transaxle back together so out to the shop I went.
After three hours of fighting with trying to align all of the gears back together, I finally got everything (including the axle housings and wheel hubs) back together! YAY!!! /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif
Well, time for bed now! I'll try to put the back half of the tractor back together with the front half!
/ JD 216 Rear Transaxle #13
Good job, glad things are working out.
/ JD 216 Rear Transaxle #14
The 200 series Deere is one of the few tractors worth the effort. It's a nasty job, but you will have a machine that should last another 20 years.
That's really what I'm hoping. At this point, it only cost me around $120 for all the parts (including a new brake ring and reverse idler gear). When it first broke, I started looking around. In actuality, the 216 is a little small for my yard (3 acres mowing). So if i were to get a new tractor, I'd be looking at around $4000 - $5000 for something slightly bigger (sticking with Deere). Also, I use this thing hard and I really don't think a lowe's tractor would hold up to the abuse. So in short, (or long as this is turning out) even an old used tractor would be starting around $2000 for my needs and at that point, I might as well fix the one I have even if it needs a new engine in the next couple years...
Sorry for the rambling!
Well... I did it!!! /forums/images/graemlins/grin.gif
Last night, I got her all back together! My wife (who loves to mow) wanted to try it out right away. Granted, it's about 8:30pm, dark and the grass is wet from the dew.
Long story short, she jumped on, mowed close to 10 inches of wet grass (we hadn't been able to mow since the axle housing broke) and the tractor didn't even flinch in 1st (not creeper) gear!
Just makes me smile. I knew these things were beasts, but that's amazing to me from a 16HP tractor...
Anyway, the saga is over! /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif
2003 Odyssey Lextra 2502 Pontoon w/ 2009 Bagg Boat Trailer (A62613)
2003 Odyssey...
New/Unused Quick Attach Backing/Mounting Plate (A65583)
New/Unused Quick...
New/Unused CFG Industrial MX12RX Mini Excavator (A65579)
New/Unused CFG...
1997 TSE UTILITY WIRE REEL TENSIONER (A62613)
1997 TSE UTILITY...
2019 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2019 FREIGHTLINER...
New 20'x20' All Steel Carport (A62679)
New 20'x20' All...
