JD 216 lawn tractor will not start
   / JD 216 lawn tractor will not start #1
alkolano
pa
216 jd
I have just got the tractor and was mowing the yard when all of a sudden the tractor just shut off. It wasn't out of gas, it was just as if somebody turned off a switch or something.
Battery is fully charged, yesterday I jump the solenoid and the starter kick on.
Could the ignition switch have failed? How do you check the 5 prong switch ?
Thanks for the help!
   / JD 216 lawn tractor will not start #2
Sounds like a safety cut off switch might have been shook loose or went bad. Check under the seat, behind the break, and behind the pto engage lever.
NEW Work Saver Skid Steer/Sub Compact Grapple (A53473)
NEW Work Saver...
2018 CATERPILLAR D6T LGP HIGH TRACK CRAWLER DOZER (A52705)
2018 CATERPILLAR...
UNUSED LANDHONOR UNIVERSAL ADAPTER PLATES (A54757)
UNUSED LANDHONOR...
New 4-10-16.5 Forerunner Skidloader Tires & Rims (A50775)
New 4-10-16.5...
(12) 2" X 6" X 41" TUBING (A54756)
(12) 2" X 6" X 41"...
2011 Nissan Rogue SUV (A55758)
2011 Nissan Rogue...
