JD 216 lawn tractor will not start
   / JD 216 lawn tractor will not start #1
alkolano
pa
216 jd
I have just got the tractor and was mowing the yard when all of a sudden the tractor just shut off. It wasn't out of gas, it was just as if somebody turned off a switch or something.
Battery is fully charged, yesterday I jump the solenoid and the starter kick on.
Could the ignition switch have failed? How do you check the 5 prong switch ?
Thanks for the help!
   / JD 216 lawn tractor will not start #2
Sounds like a safety cut off switch might have been shook loose or went bad. Check under the seat, behind the break, and behind the pto engage lever.
STRICKLAND CASE 621D WHEEL LOADER FORKS (A52705)
STRICKLAND CASE...
2022 FREIGHTLINER CASCADIA SLEEPER (A54607)
2022 FREIGHTLINER...
AGT Mini SkidSteer (A50322)
AGT Mini SkidSteer...
UNUSED WOLVERINE TL-12-72W 72" HYD TILLER (A54757)
UNUSED WOLVERINE...
2017 Ford F-150 (A55788)
2017 Ford F-150...
2018 JLG G5-18A (A50123)
2018 JLG G5-18A...
