Oil & Fuel JD 2120 Roto Diesel Fuel Injection Pump Leak
   / JD 2120 Roto Diesel Fuel Injection Pump Leak #1
SDavisH
Nashville, TN
JD 2020
I have a 2120 and diesel has recently started leaking from the fuel injection pump. It looks like it is leaking from one of the fuel pressure lines or somewhere on the bottom around the speed advance. I know I can replace the washers on the pressure lines if it is leaking there, but I am not clear on how to repair the leak if it is around the speed advance. Do I need to pull the pump and send it to a repair shop if the leak is around the speed advance?
Attached are some pics.
This thread is cross-posted on YT. I was having trouble uploading pics, so I posted it here as well.
   / JD 2120 Roto Diesel Fuel Injection Pump Leak #2
member thepumpguysc would be my best bet for some guidance here.
Try to send him a pm (message) and hope he can do that for you. He has shown to be a big help here, and knows injection pumps.
There are others too, but don't recall their forum names.
I'll reach out to him. Thanks, beenthere.
   / JD 2120 Roto Diesel Fuel Injection Pump Leak #4
Let us know the out come.
My JD 2030 had a line (to injector) leak that washer replacement fixed.
   / JD 2120 Roto Diesel Fuel Injection Pump Leak #5
Hey mate how did you get on with you fuel pump? I believe I have the same problem on my 2120. Just wanting to know if it’s an easier fix that can be done at home.
Thanks
   / JD 2120 Roto Diesel Fuel Injection Pump Leak #6
Some of the items can be fixed with pump on engine. I wouldn't remove unless I absolutely had to.
2018 Mercury Verado 250HP Outboard Boat Motor (A51694)
2018 Mercury...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
100 GAL FUEL TANK AND TOOLBOX COMBO (A53843)
100 GAL FUEL TANK...
Caterpillar 200 Forklift (A53117)
Caterpillar 200...
2019 John Deere 3025E (A50123)
2019 John Deere...
Doosan DX85R (A50123)
