JD 2032R newly added hyd top & tilt cylinders hydro locked
   / JD 2032R newly added hyd top & tilt cylinders hydro locked #1
waddell992
JD 2032R
Hi Y'all, just found & joined this community.
My problem: I'm adding hyd top & side links with a Vevor 2 spool joystick control valve. I installed a power beyond sleeve into the N port of the valve and it's connected to the +P on the tractor. The P & T ports are connected to the -P & T on the tractor.
The link cylinders move a little bit on the first move of the joystick but lock up after that, until loosening a hose fitting to release pressure.
Where did I go wrong or is the PB sleeve leaking..or?
   / JD 2032R newly added hyd top & tilt cylinders hydro locked #2
What is -P and +P? I think you probably have things hooked up backwards. The pressure supply from the pump needs to go the P port on the valve (the one nearest the relief valve) and the power beyond sleeve (N port) on the valve should supply oil back into the tractor system. I think you should revisit that.
   / JD 2032R newly added hyd top & tilt cylinders hydro locked #3
Connections to the valve you added should be:
P - port on valve to pressure from tractor.
Power beyond to supply pressure down stream like to 3 point hitch or rear remotes
T - port directly to tank
Will reversing the pressure and PB lines effect the downstream systems?
Currently my loader and 3 pt operate correctly.
   / JD 2032R newly added hyd top & tilt cylinders hydro locked #5
I for one, am still confused as to exactly what you have now. You have a loader valve (with power beyond?) and a new valve now supplied with power beyond from said loader valve? That flow is connected to the P port of the new valve, the power beyond from the new valve goes back into the tractor three point lift system? If so, that sounds correct. The loader and three point work. Yet the new valve doesn't operate cylinders connected to the work ports? If the basic plumbing is correct something must be wrong in the work port to cylinder plumbing. Either hooked up wrong or couplers not properly mated.
Went out into the snow today.
I switched the pressure supply and power beyond lines and that solved the issue.
I guess I misunderstood the fluid flow direction.
Thanks for your help.
2003 Komatsu WA250 Articulated Wheel Loader (A50322)
2003 Komatsu WA250...
2012 Volkswagen Jetta Sedan (A50324)
2012 Volkswagen...
2014 Chevrolet Impala Limited (A50120)
2014 Chevrolet...
John Deere 1560 No Till Drill (A52349)
John Deere 1560 No...
