JD 2030 Gas farm tractor Electrical question..
   / JD 2030 Gas farm tractor Electrical question.. #1
Gil A
Concordia, MO
John Deere 2030 Gas
Wiring harness shorted out and burned several wires. Rebuilding wiring harness. Two wires (Red and Black) come out of distributor. Where do these wires attach? Know one goes to coil, but which one and which post, there are a positive and negative post on coil, and where does other attach?
Thanks, Gil
   / JD 2030 Gas farm tractor Electrical question.. #2
Distributor wire goes to negative post of the coil. I only remember one wire from the distributor on my 2030 gas (only owned 3-4 years) sold over 20 years ago. Maybe some one added an extra wire for better ground??? Wire from points goes to negative post of coil. Positive post of coil should have two wires.
   / JD 2030 Gas farm tractor Electrical question.. #3
Parts wiring schematic confirms what Zebrafive posted
2012 Kia Sorento SUV (A51694)
2012 Kia Sorento...
2016 Dodge Charger Sedan (A51694)
2016 Dodge Charger...
(4) STEEL CARTS W/ WHEELS (A51248)
(4) STEEL CARTS W/...
2015 Freightliner Bucket Truck - Terex TM 100 Boom - Cummins Diesel - Allison Transmission (A53473)
2015 Freightliner...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50775)
IF YOU BID ON AN...
Gravely Compact Pro Zero Turn Mower (A53117)
Gravely Compact...
