JD 2025R or Kubota 2620?
   / JD 2025R or Kubota 2620? #1
JRJORDAN39
Deer park WA
none
Hi everyone. I am looking at the 2025 for 17.500.00. Is that a good tractor and price? I am torn between this and the Kubota 2620. Any help would be appreciated.
   / JD 2025R or Kubota 2620? #2
Welcome. I have a Kubota B2920 (same as the B2620 + 3hp). I don't have anything negative to say about it up to this point. The Kubota Bxx20 series tractors have proven themselves to be tough/reliable. I have no experience with the JD.
What do you plan to use the tractor for?
   / JD 2025R or Kubota 2620? #3
G'day Mate and welcome to TBN from Downunder.
As 'McREBEL' asks, we need a bit more detail as to what you're planning on using a/the tractor for + is that price including a Front End Loader (FEL). Also, if a FEL is included, what would you be planning on using it for.
You need to take into consideration future uses for your rig... call it your 'wish list'. :)
   / JD 2025R or Kubota 2620? #4
Wow, dd not realize the 2025's are out.
PS get the Bota.
   / JD 2025R or Kubota 2620? #6
JD 2025R.....new decals, same problems. Fight for warranty.
   / JD 2025R or Kubota 2620? #7
As noted, you are comparing a SCUT to a CUT, so use may well dictate which is the better choice. We have two BXs and just bought a new 1025R as we have several CUTs and UTs. I personally prefer the B2601 to the B2620.
   / JD 2025R or Kubota 2620? #8
I like three range hydro's!
   / JD 2025R or Kubota 2620? #9
I did a ton of research before I bought and ended up deciding between a B3350 and a 2032R. In the end it came down to the dealer/service department and which tractor I liked using better.
I'd recommend spending a bit of time at both dealerships, get a quick tour of their service departments, test-drive the two you're considering as close together as possible (test drive one, then head to the other dealer and try that one) and then make a decision.
And don't second-guess yourself. They're both top-shelf tractors. There isn't a wrong decision, which is why you should just go with the one that feels right and don't look back.
Enjoy!
   / JD 2025R or Kubota 2620? #10
For us, we went with the 1025R. The easy load loader and the drive on/off deck was the important factors to me. My wife will be using the loader for her horse barn.
2011 CIRCLE M 32 FOOT GOOSENECK (A53843)
2011 CIRCLE M 32...
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A54814)
2003 Pierce Tilt...
Pallet of UV Solid Hardwood Flooring (A53424)
Pallet of UV Solid...
UNUSED WOLVERINE TL-12-72W 72" HYD TILLER (A54757)
UNUSED WOLVERINE...
2019 MACK PINNACLE P164T DAYCAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
