JD 2020 Transmission Pump
   / JD 2020 Transmission Pump #1
Oktoc
Meridian, MS
Jd 2020 & farmall F Regular
Good morning everyone. Just had to replace the gears in my 2020's transmission pump. The gear teeth broke apart. Have been trying to figure out what could have caused the teeth to shear. My question to all the JD experts is whether or not the transmission pump is in direct line with the tractor's rear pto? I have been running a Brown tree cutter bushog clearing some land and I know it puts a great deal of stress on the pto drive train. Could the tree cutter have had anything to do with the gears breaking? I have repaired the tractor and it working fine now, but am not sure I want to put the tree cutter back on the tractor. May have been a coincidence, but just want another opinion. Not really interested in breaking my tractor into two pieces again ... Not fun.
Thanks, David
   / JD 2020 Transmission Pump #2
Trans pump gears on JD utility tractors of that era have been known to break from time to time. What type pto does your 2020 have dual stage clutch or hyd IPTO?
TX Jim, thanks for the reply. My tractor has a two stage clutch. I know that trans gears break periodically, but I know the stress that the tree cutter puts on the drive line. Just curious if the two could be connected.
Thanks
David
   / JD 2020 Transmission Pump #4
I think a load on the pto shaft on a dual stage clutch tractor will not affect trans pump gear life. Trans pump is powered by pto input shaft
Pallet of PTO Shafts & Hydraulic Cylinders (A50121)
Pallet of PTO...
Cub Cadet 7254 Compact Tractor (RUNS) (A50774)
Cub Cadet 7254...
NEW Wolverine Skid Steer Pallet Forks Hydro Adjustable (A53002)
NEW Wolverine Skid...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A52748)
Ditch Witch 6510A...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A52472)
2014 FORREST RIVER...
Fire Hose W/Holder (A50774)
Fire Hose W/Holder...
