JD 2020 Shifting Problem
   / JD 2020 Shifting Problem #1
Anonymous Poster
Epic Contributor
I have a JD 2020. When switching from Park or Neutral into any gear, many times it will grind the gears. The clutch is pushed in all the way. It's kind of like it takes too long for the gears to stop turning or that the clutch does not quite disengage the trans. If I hold the clutch in for maybe 10 seconds, it might shift fine. Is there something that needs adjusted or is this a bigger problem?
2016 Dodge Charger Sedan (A50324)
2016 Dodge Charger...
2006 CATERPILLAR 330DL EXCAVATOR (A51242)
2006 CATERPILLAR...
2011 FREIGHTLINER M2 TANDEM AXLE FLATBED TRUCK (A51222)
2011 FREIGHTLINER...
Allied 760 Loader (A50515)
Allied 760 Loader...
SET OF 48" QUICK ATTACH MAST PALLET FORKS (A51242)
SET OF 48" QUICK...
2016 CIMC 40FT CONTAINER CHASSIS (A52141)
2016 CIMC 40FT...
