JD 2010 Axel Hub Problem
   / JD 2010 Axel Hub Problem #1
Farwell
Veteran Member
Farwell, Michigan
JD 2010
I own a 1965 JD 2010 Row Crop that has had a couple issues with the rear hub and hub cap that holds the wheel to the axle. The first time the wheel actually fell off the tractor because the key that locks the axle shaft to the wheel came out due to loose hub cap bolts that I didn't find when inspecting the tractor.
Today I was moving some dirt with my FEL when I heard a bang. I looked the tractor over quickly and couldn't find any problem but decided to quit working until I found the source of the noise. I found two of the four bolts missing that hold the hub cap, the key and the hub to the axle. The bolts were there when I last inspected the tractor. When I had the first problem I torqued the four bolts according to the service manuals specs. Any idea what could be causing my problem?
2008 FORD F-450 (A50854)
2008 FORD F-450...
2000 MACK RD688 TRI AXLE DUMP  TRUCK (A51222)
2000 MACK RD688...
2023 CFG QNT45 Mini Excavator (A49461)
2023 CFG QNT45...
Swamp Buggy (A49346)
2017 Caterpillar 259D Two Speed Compact Track Loader Skid Steer (A50322)
2017 Caterpillar...
2009 Yamaha YDRE Electric Cart (A50324)
2009 Yamaha YDRE...
