JD 2004 4310 hydro no f/r
   / JD 2004 4310 hydro no f/r #1
Phil2003
Error code: two long / two short
Wires fine
Seat switch fine
Fluid levels fine
Battery and connections fine
But no movement,
Help please.
   / JD 2004 4310 hydro no f/r #2
:welcome: to TBN
Looking at the service tech manual, I don't see an error code that starts with two long. Need some help from you about your check list.
Do you have the service tech manual?
Hope we can help.
I do not have a service tech manual.
Other places here have provided the codes and they show two long and two short.
   / JD 2004 4310 hydro no f/r #4
There's a connection down by the pedals under the platform that sometimes gives troubles. Try just pushing it together.
   / JD 2004 4310 hydro no f/r #5
Brush will also cause problems with this connector if you been driving through it,
Also deep snow will cause problems
John is running again, thank you all for the hep.
John Deere Gator Utility Cart (A50324)
John Deere Gator...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A52377)
1993 Ingersoll...
City of Buckhannon - 2014 Ford Fusion SE (A52384)
City of Buckhannon...
2016 Isuzu NPR 20FT Curtain Side Box Truck (A51692)
2016 Isuzu NPR...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A53473)
Kuhns AE10 Small...
