Sep 2, 2018 / JD 2004 4310 hydro no f/r #1 P Phil2003 New member Joined Jan 8, 2005 Messages 3 Error code: two long / two short Wires fine Seat switch fine Fluid levels fine Battery and connections fine But no movement, Help please.
Sep 2, 2018 / JD 2004 4310 hydro no f/r #2 B beenthere Super Star Member Joined Aug 16, 2001 Messages 18,558 Location Southern Wisconsin, USA Tractor JD_4x2_Gator, JD_4300, JD_425, JD_455 AWS, added JD_455, JD_110, JD_X485(sold) :welcome: to TBN Looking at the service tech manual, I don't see an error code that starts with two long. Need some help from you about your check list. Do you have the service tech manual? Hope we can help.
Sep 2, 2018 / JD 2004 4310 hydro no f/r Thread Starter #3 OP P Phil2003 New member Joined Jan 8, 2005 Messages 3 I do not have a service tech manual. Other places here have provided the codes and they show two long and two short.
Sep 2, 2018 / JD 2004 4310 hydro no f/r #4 P pmsmechanic Elite Member Joined Dec 6, 2013 Messages 4,226 Location Southern Alberta, Canada Tractor 4410 and F-935 John Deere, MF 245 There's a connection down by the pedals under the platform that sometimes gives troubles. Try just pushing it together.
Sep 2, 2018 / JD 2004 4310 hydro no f/r #5 Kubota 2350 Platinum Member Joined Aug 15, 2009 Messages 692 Location Michigan, In The Thumb Tractor 2016 JD 3046R Cab ...................... Mower: 2016 Scag Tiger Cat II ZTM pmsmechanic said: There's a connection down by the pedals under the platform that sometimes gives troubles. Try just pushing it together. Click to expand... Brush will also cause problems with this connector if you been driving through it, Also deep snow will cause problems
Sep 3, 2018 / JD 2004 4310 hydro no f/r Thread Starter #6 OP P Phil2003 New member Joined Jan 8, 2005 Messages 3 John is running again, thank you all for the hep.
Sep 3, 2018 / JD 2004 4310 hydro no f/r #7 Kubota 2350 Platinum Member Joined Aug 15, 2009 Messages 692 Location Michigan, In The Thumb Tractor 2016 JD 3046R Cab ...................... Mower: 2016 Scag Tiger Cat II ZTM Phil2003 said: John is running again, thank you all for the hep. Click to expand... What was the problem?
